2015-10-25 5:16 PM
I am using the STM32F746-Discovery + STM32Cube_FW_F7_V1.2.0, Every application, example, and demonstration builds fine in System Workbench except for the Lwip application. The errors seem to be related to header files missing. I checked to see in the Pathways that the proper location of the ''inc'' folders are correct. Is there a way to download a fixed version of that application? Thanks for your assistance!!
#stm32cube_fw_f7_v1.2.0Solved! Go to Solution.
2015-11-05 5:00 AM
Hi chris,
The mentioned bug is now fixed in SW4STM32 v1.5Thank you very much for your contribution to the enhancement of our STM32 related solutions.-Syrine-2015-10-27 1:46 AM
Hi chris,
Unfortunately the issue exists. It is due to a bug in SW4STM32 side.Thanks for reporting the problem, it will be fixed in one of coming releases.-Syrine-2015-10-28 8:19 AM
Thanks for replying, Syrine. I will wait for the next release then.
2015-11-05 5:00 AM
Hi chris,
The mentioned bug is now fixed in SW4STM32 v1.5Thank you very much for your contribution to the enhancement of our STM32 related solutions.-Syrine-2015-11-05 6:49 AM
2015-11-12 5:32 AM
Syrine, do you have a link to pre-release versions of the SW4STM application examples so I can try out the corrected LWIP app?
2015-11-12 6:06 AM
Hi chris,
You have to update your SW4STM32 then use the same example already available in STM32CubeF7 package -Syrine-2015-11-12 7:41 AM
Yes, everything is working ok now. Thanks again, Syrine!!!
2015-11-13 12:11 AM
Hi chris,
It is good to hear that it was solved, thank you very much for your interest on STM32 products.-Syrine-We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
