2020-05-05 3:47 AM
My OTG (CN5) socket was damaged so i checked pinout of the board to find alternative pins to connect new OTG socket on a separate pcb and i found pins (PA9 , PA10, PA11 and PA12) for FS mode but unfortunately PA11 and PA12 are not mounted on the STM board.
Is there any way to get pins from the STM to use it as OTG storage USB driver?
For HS mode , pins (PB12, PB13, PB14 and PB15) are available , so can i use HS mode as OTG storage USB driver ?
