2017-11-07 11:46 PM
I am trying to port a code that is working with FreeRTOS to RTX. The microcontroller is the same: STM32F4.
The code uses critical sections. I have tried using the same implementation for the critical section for RTX as for FreeRTOS(BASEPRI) but I often end up in UsageFault.I know that RTX uses extensively the SVC in the code.Could it be that the Critical sections should be implemented differently ?
Do you know of any other differences between FreeRTOS and RTX that could cause problems?Best regards,
Sebastian#stm32f4 #freertos #rtx #usage-faultWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
