PA0_C/PA1_C/PC2_C/PC3_C[STM32H743XGH6]
NiM
Associate III
What is the base address for the above four GPIOs that can be set?
Also, do you have the following understanding about the above 4 pins?
Pxy_C can be set to a pin of the same function or another function by controlling an analog switch.
1 ACCEPTED SOLUTION
Accepted Solutions
Andrew Neil
Super User
https://community.st.com/t5/stm32-mcus-products/confusion-about-c-pins-pa0-c-behavior-and-functionality/m-p/787244?search-action-id=56405571184&search-result-uid=787244
2 REPLIES 2
Andrew Neil
Super User
Thank you very much.
I understand, there is no separate configuration register for Pxy_C, you are talking about whether or not it is connected via a switch to the Pxy's pins.
