2020-09-02 6:13 AM
Hello!
I'm trying to adapt an example LWIP_IAP in the STM32CubeF7 FW package written for the STM32F769_EVAL board to work on the STM32F767 NUCLEO board.
For this I've had to do a couple of basic changes:
This example does not use RTOS which makes sense because a bootloader for IAP is supposed to be as light as possible.
It's failing the netif_is_up test and there is no ping.
I enclosed a ZIP with the package. It still has the STM32F769_EVAL name but I've changed it to try to make it work with the STM32F767 NUCLEO board. Any suggestions? Soemthing else I need to change?
Ah there is no example of LWIP without RTOS for a Nucleo board. I tried generating in the STM32CubeMX and added the MCU stuff and it still does not work
I can get an example with RTOS working fine but I really need now without RTOS.
Thanks
2021-12-04 6:04 AM
Hello Renato Valentim
This is my first post in this community, because I could not find anything similar in the local communities of developers in my native language.
I am also very interested in the topic IAP for STM32F767 Nucleo.
I also couldn't find an example right away for STM32F767 Nucleo and want to adapt the STM32F769_EVAL example.
Could you please tell me how your work ended and what difficulties were in the process? If there is an opportunity to share the code, I will be very grateful.
What example are we talking about: "I can get an example with RTOS working fine". Where can I get it (link)?
I will also be interested in the option with RTOS, since IAP is only one software function, although debugging becomes much more difficult with the use of RTOS.
Therefore, I would like to first just learn how to make IAP for STM32F767 Nucleo, and then transfer the code to an RTOS device.
2021-12-25 5:55 PM
