2024-07-19 8:08 AM
I'm having some issue going from my user code running azure RTOS to the bootloader. I'm using a STM32U599
The code I'm using is the following, you can find online:
2024-07-22 12:32 AM
Jumping from rtos doesnt work for me as well, I think thats due to resources acquired by rtos, you can start your system intialiaze rtos do whatever you wanna do using rtos, set a flag in flash or rom that now you want to jump, and restart the system,,,,read the flag if its true, jump before initialization on rtos otherwise continue normal operations
