2025-03-27 3:49 AM
I built a simple HTTP webservice with an F4,
Following the code provided by this tutorial made by ControllersTech
STM32 ETHERNET #6. HTTP SERVER PART 1 || Simple Webpage - YouTube
It works well.
Now I want to secure it without adding FreeRTOS
Would be possible to implement MbedTLS without FreeRTOS?
Is there different ways to secure my webserver?
Not using FreeRTOS is a requirement for my project.
Thanks for your help
Best regard
2025-03-27 5:53 AM
Should you decide to move to ThreadX NetXDuo, we can help.
2025-04-28 3:35 AM
Hi, Have you implemented the HTTPS without RTOS. I am also trying to add the secure for the web page. I am facing issues.
Are you implemented that code?
If you implemented that code means you need to send the document . what you changed.
2025-04-28 3:53 AM
2025-04-28 4:03 AM
Thanks for your response.
can you provide the https implementation using nucleo-h755zi-q . Otherwise provide with dual core micro controller implementation.
