Ethernet KS8721BLI RMII STM32F746VGT6
DLog
Associate
2 REPLIES 2
DLog
Associate
Good day. I have successfully mastered Etnernet on the Discovery STM32F746. Now you need to solder the board with KS8721BLI and STM32F746VGT6. Can't get ping. I do not know where the error is in the program or in the connection. Please help me properly connect the chips and create a project in Cube. Thank!
Imen.D
Your description of the issue is general and t is not easy to help you based on what you provided as description.
I recommend you to start from a working example within STM32CubeF7 firmware package to identify what is going wrong in your case and confirm if the problem here seems related to the hardware or software environment.
STM32Cube_FW_F7_V1.12.0\Projects\STM32746G-Discovery\Applications\LwIP\LwIP_HTTP_Server_Netconn_RTOS
Note: Follow the instructions in the readme file in order to make the program work,
Kind Regards,
Imen
When your question is answered, please close this topic by clicking "Accept as Solution".
Thanks
Imen
