2020-11-03 7:29 AM
This proto board has a inventek system - ism43662-m3g wifi module. Using the at commands I was setting it to direct mode (at AD command). When entering this command then the communication from the wifi to the stm32 doesnot work. When in normal wifi, all communication works correctly.
Has anyone set the device to direct mode and seen this issue.
thanks
