B-U585I-IOT02A TFM Application
Hi, I have the TFM example running on my board.I'm now trying to write my own non-secured application.I kept mapping just as in original example and after programming it to board the boot validates that application is authenticated.When code reaches ...
ari_v2 by Senior
  • 1005 Views
Resolved! CAN not working on STM32L431RCT6
"Board A" is a previous revision that used STM32F103C8T6 to communicate with a device over CAN. It works great."Board B" is a new revision of the same board, but I migrated to STM32L431RCT6 because I needed more IO and it was readily available. Long ...
YvanR by Associate II
  • 2585 Views
Verifying a valid root certificate always fails.
I'm totally baffled by this one.Brief:I have 2 projects, connecting to a MQTT broker. First project is just a basic shell - Connects to broker and publishes dummy data to a topic. Works perfectly.Second project is an expansion of the First one and is...
Eugene G by Associate III
  • 1551 Views
FreeRTOS error, "waiting for unfinished jobs"
Hi, I am very new to STM32. Also new to programming, IDE etc. I am trying to make an OLED print out some text on the screen. I am working on a B-L462E-CELL1 dev_kit.  I don't know what to do with this error.  I get this error(can also be seen in the ...
Fates by Associate II
  • 2211 Views
TCP_Echo_Client_PPP with P-L496G-CELL02
I would like to try a PPP connection with P-L496G-CELL02 + BG96 board with X-CUBE-CELLULAR v7.0.0.Among the available demos I have not found the one that realizes the PPP connection. I don't want to buy another board so I tried to modify the L496_BG9...
tommy by Associate
  • 778 Views
Difficulties with Writing to the Flash of STM32L4R5
Hi,I'm using an S-record file to update the MCU Firmware Application of STM32L4R5 through a Bootloader.Most Row Addresses of the S-records in the file are at the 16-byte offset of a flash row (e.g. 0x08010010, 0x08010020, 0x08010030) but there are so...
Shadow by Associate II
  • 1770 Views
