Wrong register BRR in usart
Posted on July 30, 2014 at 15:16Hi, I'm trying to initialize a usart, and read some data on a Terminal. The terminal receives some data but not the good one. The problem seems to be a clock problem, and the usart register BRR looks wrong. Moreover, ...
maxime by Associate II
  • 2641 Views
  • 11 replies
SSD1289 STM32CubeF4
Posted on July 29, 2014 at 18:16I am a beginner with Stm32f4discovery (version stm32f407vg). It took me a long to get the graphic LCD work (copying and rewriting some code from others). My problem, I want to use it with FreeRTOS. But My FreeRTOS wor...
Wrong values in debugger
Posted on July 21, 2014 at 13:34Hi everyone,I'm using CooCox with a STM32F4. I have a big issue with the Coocox debugger:static STEP_MODE val_step_mode = FALSE;1  if ((Get_Core_Current_Track()->step_mode)  !=  val_step_mode)2  {3         val_step_mo...
4 USB virtual com port cause blue screen
Posted on July 29, 2014 at 11:55hi,allI have 4 boards of stm32f103 with USB virtual com port enable using the VCP library and driver. The main purpose of the USB is to catch running log.So here is the situation:I plug in 3 boards to PC, and all of t...
non-HAL code for STM32F427
Posted on July 28, 2014 at 12:28Hi All, Does anyone have non-HAL firmware code dump for STM32F427 or STM32F4xx series controller for doing low level verification. Please share the zip file or link if anyone have it. Thanks in advance. #dfu #stm32...
umamahesh by Associate II
  • 1876 Views
USB OTG HOST Enumoration
Posted on June 05, 2011 at 12:58Hi:I got stuck trying to use STM32 Connective line controller towork as a USB HOST. If I attach flash drive the device attaching is detectedbut the enumeration is not working. USB Control packet is send but the device...
iozho by Associate II
  • 6098 Views
  • 16 replies
STM32F407 OTG FS Channel Halt Problem
Posted on July 26, 2014 at 07:39Hi,Presently i am working with STM 32F407 USB FS, when i was writing some data into the channel then automatically  channel disable bit set in to the channel characteristic register and channel transmission interrupt ...
chandu1 by Associate II
  • 742 Views
