NetxDuo ptp_client.c question
I use stm32f427 I find the NetxDuo can run so good.But When I want to run ptp_client.c I find a lot of difficultsCan  ptp_client.c support  E2E  ? or only P2P, If support both how to configure ?I use a master clock that only can support E2E , It can'...
WTieg.1 by Associate II
  • 370 Views
Resolved! NUCLEO-F446RE FreeMODBUS Library
Hello ST,I have been working on trying to get the FreeMODBUS library working on the NUCLEO-F446RE development board. The FreeMODBUS library can be found here,https://github.com/cwalter-at/freemodbusI am having trouble getting the USART port working c...
TCP fasttmr
I have created TCP client on my STM32H723 module. Now I am stress-testing the code by abruptly closing the server before the TCP client could connect. As per my code it retries TCP connection after 30 seconds. But after multiple times the code freeze...
AZURE RTOS PESSRAE certification
Hello. This is HPNRT Co., Ltd. We are currently in the process of PESSRAE certification for our escalator auxiliary brake, a component that requires certification. We are developing the system using the STM32H743 MPU and plan to use Azure RTOS as the...
Bhong.11 by Associate
  • 712 Views
