HAL and STD libraries
Posted on August 21, 2017 at 13:23Hi!! Project(STM32F4) is written using the STD library, but in HAL libary much easier to work with ethernet. How do you think it is possible  to use HAL and STD library together?  #stm32f4 #std_lib #hal
LWIP Udp Maximum Payload Length
Posted on August 21, 2017 at 15:18hi everybodyi am trying to transfer large amount of data through UDP to PC from my STM32F407.the problem is when i want to send more than 1500 bytes , i get nothing on PC side.it seems LWIP (which is generated and c...
Resolved! I cant jump while loop in main
Posted on August 18, 2017 at 15:52After I jump to the system memory location to make bootloader I cant jump back even if I press reset pin.How can I properly jump new code to run?(I am working on stm32f4 discovery)#bootloader #stm32f4
