Barcode Scaner in USBHID
Hoang_Tran
Associate III
I'm trying to use the stack usb hid to talk with a barcode scanner. When I connect the scanner it is classified as a keyboard, but does not generate the interrupt events. Does anybody know why?
8 REPLIES 8
Hoang_Tran
Associate III
up
Hoang_Tran
Associate III
help me
Pavel A.
Super User
Does it work with other, real keyboards?
Which STM32 is it? For some families, update to the latest CubeMX library version can help.
-- pa
I am using the latest Cubemx version!
It works normally with a normal keyboard, but when used with Barcode, the Usb only Start, not ready
You've got all the equipment in front of you, instrument the code to understand the interaction and perhaps augment that with a USB analyzer if you have one. Perhaps use a software based monitor on a PC, and compare.
Pavel A.
Super User
As Clive advised, you need to debug with a USB analyzer or debug prints
Matthew_ST
Associate
Hello, I have the same problem in my program, did you solve it?
Pavel A.
Super User
The HID host goes to "ready" state after completing few class-defined requests to the device.
Looks like some request fails or the device does not respond.
Debug to understand where it's stuck and how to recover, and use a USB sniffer.
If this sounds not feasible, find a consultant/contractor who can do it for you.
-- pa
