2023-12-25 8:15 PM
I tried to merge both x-cube-spn2 and x-cude-mems1. It results to errors. problem is protocols and pin configurations are clashing. I can see the configuration and settings of X-cude-mems1 as it have ".ioc" file but not in the case of x-cube-spn2. I simply want to stack them both and control stepper using gyroscope.
2023-12-26 12:01 AM
Hello @PavanKaruchola1
For the protocols and pin configurations of the X-Nucleo-IHM02A1, you can find details on the file:
Best Regards.
STTwo-32
2023-12-26 4:32 AM
Thank you for response sir. I want to start it from the beginning, How to make two expansion software work at a time in one Nucleo-board. Any example videos can help me.
2023-12-26 6:54 AM
I suggest you to start your project using the example provided in the .X-CUBE-SPN2. Then, try to add the X-Nucleo-IKS01A3 shield referring to the X-CUBE examples.
Best Regards.
STTwo-32
