2019-10-30 1:55 AM
Error - 8700 : Frame wait time out OR no tag
Even though a writeis succesfull, I will at one time get this error code back (this is the answer of the SendReceive, the result of SendReceive itself is errorcode '4 ' which stands for Communication Error), and another time a succes code. I know the write is succesfull because in the next read I can read the value that was written.
The problem with this is that I cannot check whether or not the write was succesfull and then try again, because this may put me in an infinite loop.
What can be the cause of this?
2019-11-04 1:57 AM
See the following post for this issue: https://community.st.com/s/question/0D50X0000AFqKjkSQF/why-does-my-cr95hf-respond-with-0x87-timeout-or-no-tag-after-successfully-writing-to-a-ntag216-nfc-forum-type-2-compliant-tag
Rgds
BT
2019-11-04 1:57 AM
Rgds
BT
