2024-06-13 8:34 AM
I have a c++ project using the ST25R95 as a reader talking to a STM32L4 micro. I want to play around with putting it in tag emulation mode so I can use an external reader to read data from it.
I see references to emulation in the data sheet but don't really see how to put it into this mode. Is there any example code or instructions for doing this?
2024-06-14 12:40 AM
is your application based on ST RFAL library or do you have your own NFC communication stack?
X-CUBE-NFC3 provides the RFAL library for the X-NUCLEO-NFC03A1 board. It support a polling demo and has the framework for the Card Emulation mode. The driver file for CE mode on top of X-CUBE-NFC3 is delivered on demand. I will send it to you.
Rgds
BT
2024-06-14 12:40 AM
Rgds
BT
