2024-12-13 9:10 AM
I'm currently using a ST25R3911B-DISCO board at work.
Yesterday my laptop was running Windows 10 Enterprise (don't know the exact build version) and everything was ok. The board was being discovered by ST25PC-NFC and I was able to use it with our custom host tool.
This morning my laptop got updated with Windows 11 Enterprise 2H24 26100.2605. When i plugged the reader I saw the peripheral installation message and shortly after the installation success. I tried to open ST25PC-NFC and it was not able to detect the board anymore.
If i plug the board into another win10 PC it works fine and gets detected correctly by ST25PC-NFC.
Is this a known problem and is there a solution to get the ST25R3911B-DISCO working on win11 or should I just downgrade my laptop back to win10?
Emanuele Somma
2024-12-17 1:08 AM - edited 2024-12-17 1:10 AM
what version of ST25PC-NFC are you using?
Version 3.0.0 and above now embed MSVC redistributables that were missing for Windows11.
Please give it a try and let us know :)
You can download it from this page: https://www.st.com/st25pc-nfc
Best regards,
Damien
2024-12-16 1:31 AM
Hi Emanuele Somma,
a similar issue has been reported quite some time ago, but not again seen:
Maybe you can check if there are similar symptoms on the HID device?
It sounds this could be more of an USB driver issue during the update - maybe you want to check also:
BR, Ulysses
Best regards,
Damien
