ST25PC and NFC06A1 on a P-NUCLEO WB55 development board
DS.4
Senior II
Would like to use the ST25PC GUI to test a tag (ST25DV04K) ( in ST25FTM mode specifically)
As i have difficulties finding a ST25R3916,
I would like to know if I could use a X-NUCLEO-NFC06A1 on P-NUCLEO WB55 development board to communicate with ST25PC.
Could I in a simple way change the ST25R3916-DISCO proj and adjust it to my board?
if not can you recommend for my type of use what will be better: ST25R3911B-DISCO or CR95HF .
Thanks!
1 ACCEPTED SOLUTION
Accepted Solutions
Brian TIDAL
ST25PC can be used with ST25R3911B-DISCO or CR95HF transceiver from the M24LR-DISCOVERY evaluation kit. I would recommend to use ST25R3911B-DISCO or CR95HF transceiver rather than porting on  P-NUCLEO WB55.
Rgds
BT
1 REPLY 1
Brian TIDAL
Rgds
BT
