NFC coil antena CADSTAR PCB Footprint
Andrew Lohmann_2
Associate III
Posted on August 08, 2017 at 16:04
Do you have CADSTAR 17 or lower footprint for either the 14x14mm square single sided or the double sided PCB version. I am working on a four layer design so a four layer coil or using any two or three layers design would be acceptable.
It is for M24LRxx IC.
DXF file format may also be acceptable?
#m24lrxx #14x14mm-coil
1 ACCEPTED SOLUTION
Accepted Solutions
Andrew Lohmann_2
Associate III
Posted on August 11, 2017 at 10:33
Quadrasol who support CADSTAR in the UK have helped me with a PCB foil pattern that I can paste as a shape or wires. I can go with that but I was hoping to make a Library part with a symbol and footprint.
2 REPLIES 2
Andrew Lohmann_2
Associate III
Posted on August 08, 2017 at 22:56
I have posted a follow up question elsewhere about the relative performance of the various reference designs.
Andrew Lohmann_2
Associate III
