2016-04-24 2:36 AM
Hi All,
I have downloaded the stock M24LR firmware from the official link found.I have also downloaded STVD for STM8 found .I open the example firmware in STVD, and attempt to compile the project. I get the following error:----------- Project discover - STM8 Cosmic - Configuration Debug -------------Compiling ..\..\src\main.c...cxstm8 +mods0 +debug -pxp -no -pp -l -dSTM8L15X_MD -dHSE_VALUE=4000000 -i..\..\..\libraries\stm8l15x_stdperiph_driver\inc -i..\..\..\..\libraries\stm8l15x_stdperiph_driver\inc -i..\..\inc -i..\..\..\..\librairies\stm8l15x_stdperiph_driver\inc -iC:\Hstm8 -clDebug\ -coDebug\ ..\..\src\main.cError creating process for executable cxstm8The system cannot find the file specified.Failed to create process.main.o - 1 error(s), 0 warning(s) #stvdSolved! Go to Solution.
2016-04-24 8:17 AM
Ok so I figured out the cause of the problem. If you read section 1.3 of the ''ST Visual Development.pdf'' in the release notes provided with STVD you will find the following information:
''STVD Release 4.3.9 was validated using the Cosmic C toolset versions 4.4.2 for STM8. In order to use the Cosmic C toolset with STVD, the cvdwarf.exe Cosmic convertor is needed to generate the .elf debug information files required by STVD. The cvdwarf.exe Cosmic converter is included in the Cosmic C toolset versions 4.2a and later. User can download this version or a later one from the www.cosmic-software.com web page.''Therefore to resolve the issue you need to install the cosmic C compiler as well as STVD in order to compile the project. You can find the download link to this compiler below:http://cosmic-software.com/download.php#stm82016-04-24 8:17 AM
''STVD Release 4.3.9 was validated using the Cosmic C toolset versions 4.4.2 for STM8. In order to use the Cosmic C toolset with STVD, the cvdwarf.exe Cosmic convertor is needed to generate the .elf debug information files required by STVD. The cvdwarf.exe Cosmic converter is included in the Cosmic C toolset versions 4.2a and later. User can download this version or a later one from the www.cosmic-software.com web page.''Therefore to resolve the issue you need to install the cosmic C compiler as well as STVD in order to compile the project. You can find the download link to this compiler below:http://cosmic-software.com/download.php#stm8We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
