2022-01-05 2:24 AM
Using ST25RU3993, I was able to get only the On-chip RSSI value and EPC,PC values.
Is reading the temperature sensor value, implemented in the SDK?
If NO, How can i implement it??
The temperature Sensor which I am using is "RFM3200-AFR"(Gen2 compatible).
2022-01-05 4:48 AM
I guess this is the same request as st25ru3993eval-access-memory-bank-of-temperature-sensor.
We have all the required information and colleague of mine will provide an answer after this holiday period.
No need to double post.
Regards, Ulysses
2022-01-05 4:48 AM
Regards, Ulysses
