2016-09-22 3:17 AM
Can nfc03a1 read/write the tag m24lr. In the datasheet of CR95Hf; it says that ISO15693 tags are supproted and forum tag types 1,2,3,4 as well. M24LR belongs to Forum tag type V and it supports ISO15693. So I could not make sure that can I use CR95hf as transciever for m24lr tag.Thanks in advance.KawtharSolved! Go to Solution.
2016-09-26 4:51 AM
Hello Kawthar,
Yes CR95HF support the M24LR familyPlease check AN3375 on :
http://www.st.com/resource/en/application_note/dm00025202.pdf
In addition of the NFC03 board, there are some development kit call M24LR-DISCOVERY that provide boards with CR95HF and M24LR. You will find information
on chapter Tools and Software, folder EVALUATION TOOLS
2016-09-26 4:51 AM
Hello Kawthar,
