SPV1050 MPPT resistor
es
Associate
There is confusion about resistor values on input voltage divider.
According to datasheet voltage on MPP pin should be lower than 2.1 V (Vuvp - 0.1V)
In application note AN4397 you used UVP set by resistors R4, R5, R6?
Which value should be used?
0 REPLIES 0
