2004-01-30 2:57 AM
2011-05-17 1:17 AM
hi i m using st72141.
How can i use i/o ports to supply my speed information to tachometer? or what is other way that i can display my speed information.? Regards BK2011-05-17 1:17 AM
if I have well understood, you are looking for something that allow you to output from your system (ST72141) the data relative to speed? But you don't specify if the output device is a monitor (to show them), a led display or another device. Generally, the tachometer is used as sensor 'to input' the speed... Please, clarify these points. Regards, TanioWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
