2005-12-25 8:15 PM
NOISE IN SWITCHING MOSFET(STGF20NB60S)
2011-05-17 1:19 AM
Hi!
We are driving MOSFET thru SG3524 pwm driver. When we connect load(Resisitive) to Drain we are getting perfect results. When we connect load to source, 'ON' is working perfectly, but during 'OFF' , Voltage across Drain and Source is Drain Volage plus noise is appearing. Suggest me to overcome the noise across Drain and Source. Thanking you AnandWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
