2007-05-23 2:52 PM
2011-05-17 1:14 AM
Hi!
I am trying to run a 29v BLDC motor at 50,000rpm in either open or closed loop mode. I have read the threads relating to maximum speeds, and also application notes. However, I am still a little confused about how to calculate this. Any help, or pointing to further documentation would be great! Thanks, Kel2011-05-17 1:14 AM
Hi Gigi,
Thanks for your help. I have a motor with only 1 pole pair. So it looks like the maximum RPM = 680Hz * 60 / 1 = 40800 (is there any way to increase this?) Hopefully this will be sufficient! Thanks again! Kel2011-05-17 1:14 AM
Hi gforte,
Thanks again for your help! I will see if 40800RPM is fast enough, and will try modifying the settings if it's not. I'll let you know how it goes. Thanks so much! KelWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
