2020-01-30 7:36 AM
Hi all,
The LED6000 has a seperate EN and DIM line. I would like to use the dimming feature and also be able to disable the device. It seems I could use DIM only, and tie EN to VCC. Then, if I hold DIM low, the device should be disabled. As I use multiple drivers in my design, I only need 1 line per driver from the microcontroller.
Does anyone know if this is correct?
