2025-10-15 12:32 AM
Hi ,
Recenlty I designed the my custom board with LDL112PV33R . My Vin is from Battery charger BQ25620 which is 3.7V. Now LDO giving directly 3.7V at Vout. I done following diagostics.
Now i have order my 10 board with This LDO. This part is not locally available in india to check where those IC are damaged or not by replacing with new IC.
Help me out.
2025-10-15 2:25 AM
Welcome @sauravpanchal369, to the community!
The marking is the right one for the LDL112PV33R.
Unfortunately, you did not include your layout, so we cannot check it. However, pin 2 (GND) is not connected, so please connect it to GND.
/Peter
2025-10-15 2:25 AM
/Peter
2025-10-16 12:24 PM
Hello @Peter BENSCH ,
Thank you very much for pointing out that. I connect pin2 to ground externally and it worked.
Thanks again
Saurav
