2023-10-15 9:27 PM
Do we have a clear Pin Numbering configuration for this component as pin numbering which is 1,2,3 the datasheet did not clarify clearly.
2023-10-15 11:37 PM
Welcome @Sakura, to the community!
You can see the pin assignment actually also in the drawing of the TO-220, which is essentially the same as the arrangement on DPAK and P2PAK:
Hope that helps?
/Peter
