2015-01-14 12:05 AM
We have noticed that the Run command is able to run slower speed as the Move command, even with a minimal Minspeed. Is that correct/normal or do we have a code error on our side? Thanks y advance, Best regards Ric2015-04-08 1:05 AM
Hi Ric,
the behavior is correct. The Run command resolution allows reaching lower speed values compared to the positioning commands. The speed of the positioning commands is limited by the MAX_SPEED parameter. Regards EnricoWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
