2015-07-30 9:53 AM
I have had partial success in using the L6470 eval board. However, I found that when I issue a GoTo (ABS_POS) command, it doesn't execute right away. Interestingly enough, it starts executing after I send a ''disable'' command! (A subsequent ''disable'' command it then necessary to cut power to the motor.)
Any idea what might be going on? Am I missing a step in this process?2015-07-30 10:04 AM
Oops. Never mind. I just found out that I wasn't sending all four of the bytes required by this command, which explains why it wasn't executing right away.
