2020-02-20 11:13 PM
Hi all,
I have questions about L6470 absolute position counter:
Thank you,
MT
2020-02-21 5:19 AM
Hello MT,
Welcomes!
Kurtnelle.
2020-02-22 12:11 AM
Hi Kurtnelle,
Thank you for the answers.
For 3, I have seen these two situations that ABS_POS is different from what GoTo_Dir() specifies:
A. Run GoTo_Dir() in reverse direction to 0. Occasionally, the ABS_POS is greater than 0 (but not too far off) after execution.
B. ABS_POS does not seem to change after GoTo_Dir() executed, although the load does move to the desired location. This happens rarely.
SPI clock is 5MHz. Step-mode is 1/128 micro steps.
Since the values of ABS_POS are not random (at least somehow correlated), it does not seem like a data corruption situation to me.
I wonder what may cause these? Can you or others please give some suggestions?
Thank you,
MT
