Using L6599 STBY pin for power output control through PWM
Posted on June 26, 2017 at 14:37Hi, I'm trying to design an LED driver using L6599 and L6533 (boost then LLC) stages, I'd like to know if I can use a 300Hz PWM on the STBY pin of 6599 to drive the output in a PWM dimming control? The datasheet doesn...
