Power management
RHFL7913 application note
Does anyone help me to get application note for RHFL7913. and also block diagram for RHFL7913 SMD5C package.Regards,Swamy M.
SM.11 by Associate
  • 847 Views
NCP398MUTBG protection for USB 3.0 TYPE C VBUS design
For the NCP398MUTBG it states that It protects VCONN against overvoltages in applications where VCONN isdirectly derived from the VBUS supply. In my application I am not using VCONN. I am using VBUS of a USB 3.0 TYPE C as the power supply for my desi...
SDavi.15 by Associate
  • 669 Views
L6388E design support
Posted on June 27, 2018 at 15:21Hi all,I'm in the process of bringing up a new design using the L6388E gate drivers. However, I've run into a stumbling block. Hopefully its something stupid in the design, but I'm at a loss: was wondering if anyone h...
How to design a snubber for pushpull inverter?
i am in the process of designing a push pull inverter.I had heating issues in primary and i happen to probe the drain voltage of the mosfets connected across the halfs of transformer.The images of the ringing of the drains have been attached.How shou...
Amal Babu by Associate III
  • 1693 Views
Implement Position Control of a brushless DC motor using an STM32
Hi,I need to implement a motor positioning controller for a brushless dc motor. So far I can only find references to speed / torque control in the ST libraries. Where can I find information regarding position control? (I would like commands like GoTo...
moshe by Associate
  • 805 Views
