LM317T vs LM317BT
What is the difference between LM317T & LM317BT?
Hello, I'm trying to work with The STSPIN32F0A to drive bldc motor and do some position control. Unfonrtnuelly I wasn't able to find any of those apis in the library:GoHome(),GoTo_ABS (ABS_POS)GoTo_DIR (DIR, ABS_POS)GOTO (INC_POS)Dose anyone used tho...
I know that Vout = Vs * KvalI know that Kval = [(Kval_x * BEMF_COMP) * VSCOMP * K_THERM]*microstepIn the datasheet KVal_x is either KVAL_ACC, KVAL_DEC, KVAL_RUN, or KVAL_HOLDdepending on the state of the motion planner.But, I am not using the inter...
Hi. I have a question about the STM32 NUCLEO F334R8. I connected the usb cable to the computer, compiled the generated clean code, clicked debug and terminate and I have such an error. What can it be about?
Hello all,We made a custom board using stm32mp157 and stpmic. Board is booting, we're using openstlinux, we have prompt and so on.We'd like to use PMIC_SWIN / PMIC_SWOUT funtionnality (swin=5.2v). On the PMIC datasheet it say that we have to set SWOU...
I have doubt while I am placing this part TO-220AC as a horizontal mount how much pad size I should use. heat sink pad exist on top or for full package on bottom side..
