Hi,When searching "L78M12", there are two results in ST web site. One says that "L78M12AB" is obsolete. The other one says "L78M" is active. For both of them, there are links to datasheets. One datasheet is obsolete and the other one is active. I loo...
Hello. I'm Using L9369 for H-bridge control.I'm trying to set GIO0~8 pin high(Button interface), but i can't(Analog Output - SPI control)i'm using SPI command, and i saw L9369's manual and i follow the instruction below steps to set GIOx pin as high....
Hi, Can I learn MTBF value of "SCTW90N65G2V" MOSFET?or, How can I calculate?
HelloI couldn't find it on the official website of the product.I have download UM2270 document but couldn't get firmware source.Where can I get the source code described in the UM2270 document.Best Regards,J.P Hong
Can you share with me MTBF value of this product:L7805ACD2T-TR?
In my previous post I showed a fault condition using a STSPIN240 and a brushed DC motor with a supply voltage of 9V. I assumed that this issue would be resolved if I instead used the STSPIN250, as this would allow the current protection limit to be d...
