2021-07-30 7:03 AM - last edited on 2023-08-31 1:06 AM by Peter BENSCH
Could you please help check the normal range of resistance vaule between Pin A1 and Pin G ? Will it be higher than 72.5ohm? Or will the resistance vaule become higher due to some manufacturing process?
2021-08-02 12:23 AM
The component T2535-600G is a TRIAC, i.e. a semiconductor. The result of a resistance measurement therefore depends on the measuring device used (measuring current, etc.) and is therefore not reproducible. So there is no such thing as the "normal resistance value".
/Peter
2021-08-02 12:23 AM
/Peter
