2018-07-06 7:23 AM
Hi, guys!
Trying to connect the MCP4725 DAC to my STM32F103RB by following this tutorial:
https://learn.adafruit.com/mcp4725-12-bit-dac-tutorial/
Sadly I'm getting no response. I've tried with a regular Arduino UNO, where everything works as it should. Also tried running a i2c scanner code, which gave no results. With the Arduino the correct address is 0x60.So do anybody know what I can do differently to get this working? Should the wiring be any different? What upload settings should I use?Best regards,Peter#i2c #f103 #arduinoSolved! Go to Solution.
2018-07-09 12:42 AM
Fixed it! Just had to add some pull up resistors! Works fine now :)
2018-07-09 12:42 AM
