2013-06-21 5:49 AM
I am starting a new project using a STM32F051K4U6. I have not used an ARM ever before, I've mostly used 8 bit micros, lots of MSP430 work in the last few years.I am very familiar with IAR EW, been using it for 10 years. So, of course I looked there first when deciding on what to use for the STM32 processor. The EWARM is sooo damn expensive! It's like $3400 - $7000 or something like that.I've gotten pricing for some of the others, Tasking, Keil, I forget what else, they are less certainly but is it worth it to use the IAR as I have used it so much? My knee-jerk reaction is that it is probably *not* worth it ... I've learned plenty of development environments, I can probably learn another.I'd appreciate any feedback regarding this.Thanks.Mike #eclipse-gcc-gdb #eclipse #iar2013-06-22 10:36 AM
<i> I would put my trust in Keil, as it's owned by ARM. There is an obvious advantage in codesize and performance, compared to gcc based toolchains.
I'm missing the experience with IAR here ...</i> having worked with both Keil and IAR in my opinion one is six and the other is half a dozen2013-06-22 10:38 AM
I'm missing the experience with IAR here ...</i> having worked with both Keil and IAR in my opinion one is six and the other is half a dozen. If your volume is enough (to be allowed to) ask the ST FAE, you will get better support using what (s)he is most familiar with, Erik2013-06-23 3:37 AM
I had been working with (fully licenced) IAR WB for MSP430, which doesn't say much about the quality of the ARM compiler ...
2013-06-24 6:20 AM
Hi Mike ,
You also can try the following combination : Eclipse Juno + http://sourceforge.net/projects/gnuarmeclipse/ + https://launchpad.net/gcc-arm-embedded ( which also have FPU Support). There are many tutorial on the web on how to set-up the environment , here is one : http://www.sectiongo.com/main/setup-eclipse-debug-environment-for-stm32f4-discovery-board/ Michael2013-06-25 1:42 AM
I like
very much, it's NOT based on Java (eclipse) ide so it works very smooth and fast. Disadvantage is that it is new and therefore not yet a big group of users that can give you support. The developer will give quick and accurate reply on the forum. Have a look at it, it's free.2013-06-25 7:16 AM
''NOT based on Java (eclipse) IDE - so it works very smooth and fast.''
Aha - so revealing what something is not - now serves alone to ''fully/convincingly'' justify choice/use! Pure opinion (perhaps promotion) - absent supporting reason - may not capture all, ''hearts/minds...''2013-06-25 8:20 AM
I have no opinion of the suggested IDE, but Eclipse is a pain in the butt unless you like coffee breaks waiting for your click to be executed. for that very reason I will state ''Eclipse is not fit for professional development'' Erik2013-06-25 8:30 AM
I did try Em:Blocks.
Works well in my opinion.Eclipse can be a real pain when first learning the IDE.2013-06-25 10:17 AM
... but Eclipse is a pain in the butt unless you like coffee breaks waiting for your click to be executed.
That problem disappears if you update to a i7 core + 4GB RAM ... Do you know the ''slowness detected'' - IDE named NetBeans ? I believe those Java-based IDEs are one of the IT industries efforts toward planned-obsolescence ...
2013-06-25 12:30 PM
<i>That problem disappears if you update to a i7 core + 4GB RAM ...</i>
''pain in the butt slow'' observation made with win7 and 8GB RAM, dual processor, bells, whistles. I have compiled >300kB with Keil/IAR on ''non-stellar'' machines faster than 60kB with Eclipse/GCC on the above. OK, I may be wrong it could be the CGG; however Keil/IAR does not use Eclipse, we are in the situation where someone abusing the title ''software developer'' hide their incomptence behind ''just get a faster machine''. is it not strange that the ''go green'' people keep harrassing Dell and HP but have no comment on software requiring a machine using more power to make the products from incompetent developers usable.We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
