2020-07-27 10:46 PM
Kindly share the availability and sales office details.
Suppose you stopped the above product kindly recommend the equivalent product for the above part numbers
2020-07-29 6:16 AM
The LM324 and LM358 are still in production, but DIP packages have been obsoleted many years ago, as you can find in the revision history of the datasheets.
If you cannot switch from THT to SMT you could ask your local dealer for LM324N/LM358N from other suppliers.
Good luck
/Peter
2020-07-29 11:18 PM
2020-07-30 1:08 AM
The importance of DIL packages has decreased dramatically during the last 20 years as SMD hs become a de facto standard. Therefore I cannot recommend any alternative device in DIL/DIP.
Anyway: both LM324N and LM358N can still be found at e.g. Arrow.
Good luck
/Peter
2020-07-30 3:19 AM
2020-07-30 5:15 AM
Need to find a sharper sourcer, and stock enough parts to cover your expected usage demands
https://octopart.com/search?q=LM324N¤cy=USD&specs=0
https://octopart.com/search?q=LM358N¤cy=USD&specs=0
2020-07-30 10:27 PM
