2008-03-28 7:47 AM
2011-05-17 2:51 AM
I have 100 units with uPSD3334DV
From some reason during the operation in 10 units the CPU stoped function and change the out-port data - after power cycle the system return to work properly I checked Volatges, Crystals and it was fine I know it too general - but do somebody have any idea what can cause this problem joeil2011-05-17 2:51 AM
I had the same problem. The reason was that the I used the battery backup function for the SRAM. The battery voltage was rising above Vdd and the SRAM goes to protected mode. Best Regards, André ArdeschWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
