2004-02-22 5:21 PM
2011-05-17 2:58 AM
can I use a different baudrate for each uart. I'm currently using timer2 as baudrate generator. Thanks.2011-05-17 2:58 AM
hi
Yes you can use a different baudrate for each uart. Uart0 use timer2 and uart1 will use timer1. To select timer2 for uart0 set RCLK = 1 ,TCLK= 1 in T2CON To select timer1 for uart1 set RCLK1 = 0 ,TCLK1= 0 in PCON see T2CON,PCON Register detail in the data sheet hanan [ This message was edited by: hanan54 on 23-02-2004 06:53 ]We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
