2004-03-25 11:49 PM
2004-03-21 8:32 PM
How do I configure the UART of 6230 to transmit data without having to use an external inverter?? I have tried complementing the byte before sending it out , but that didnt work. How can I resolve the issue???
2004-03-24 9:39 PM
You cant - you need the inverter. It will make no difference inverting the byte, as there are other parts of the RS232 signal before and after the data - the start, parity and stop bits. if these bits are not the correct polarity, your data is useless. Simon2004-03-25 11:49 PM
I used an external inverter and it works now.
Thanks, Sushma.We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
