2003-05-12 11:40 PM
2003-05-05 10:43 PM
I would like to transfer hex or bin file to PC comm port IF anyone has some example code for the same.???2003-05-09 3:23 AM
Be more precise: do you want to send your hex or bin file from a ST7 to the PC? If yes, this can be done through the SCI communication peripheral for instance. You will find some application notes giving code on this site.
2003-05-12 11:40 PM
One Application Note is present i.e. AN 969 (SCI communication between ST7 and PC). You can download it from the same site.
