2003-04-24 1:50 AM
2003-04-23 4:26 AM
I've made an s19 file with Cosmic's IDEAST7 and when i load it in the STVP I get an error: ''Address between 0x10 and 0x2F is out of range ! - STOP loading'' What is he trying to write in this adress range. What is going wrong? Regards, Johan2003-04-23 2:30 PM
There are any errors in your *.inc file. It means HW Registers has any errors.
2003-04-23 8:17 PM
IdeaST7 hasn't created any .inc file, i think this is only in case of asm files and i'm writing in C.
What are the HW registers, where can i change those? Regards, Johan.2003-04-24 12:28 AM
Please check your map file. Which mcu are U using? U can download mapfiles from the ST web site. Cheers F2003-04-24 12:49 AM
Is the map file created with the information out of the lkf-file? In my map file i find several variables in this adress range, but the compiler has placed them overthere (i think). I'm using a ST7lite29 and program it with a the ST stick. Regards, Johan2003-04-24 1:50 AM
Please can U check first this attachment? (map files for different mcus, including st7flite2)
Rgds F ________________ Attachments : mapfiles.zip : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I06m&d=%2Fa%2F0X0000000bTl%2FQ8VbPUMt3xKQP99H6ZqkrBkf_JdcaQIWGS49Ymy5ZCQ&asPdf=falseWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
