Stv0900
Alexandre9009
Associate
Hello and respect, I downloaded the stv0900 data sheet from the site and it was 5 pages, and unfortunately there was no information about the stv0900 pins in it, is it possible to send me the complete document? I need information about its pins and connections so that I can design its circuit and use it for a demodulator in my board.
1 ACCEPTED SOLUTION
Accepted Solutions
Correct, there is nothing officially available from STMicroelectronics anymore.
4 REPLIES 4
Peter BENSCH
The STV0900 was discontinued a long time ago, apart from the data brief there is no more information about it.
/Peter
Thank you for your answer. Does that mean there is no way to find the complete data sheet and document related to this part?
This class of device is also likely behind NDA/SLA which preclude the distribution of IP and related documentation. ie only to top-tier STB makers when it was an active product. I also expect related staff have been let go or reassigned.
Expect to have to reverse-engineer anything you need.
