2006-10-31 2:32 AM
2011-05-17 12:33 AM
have a lock to this thread. The code is for IAR
but use the STR91xlib. http://mcu.st.com/mcu/modules.php?mop=modload&name=Splatt_Forums&file=viewtopic&topic=4376&forum=212011-05-17 12:33 AM
Gentlemen(Ladies):
I am having quite a bit of trouble getting the UART0 Receive interrupt to work. I am using the Keil/ARM Realview compiler. Does anyone have an example of working code that works the UART0 Receive interrupt? Thanks in Advance, -=Rich=-2011-05-17 12:33 AM
Hi RichMcCoy,
please find attached an UART project using interrupt under IAR Compiler. I hope that it will be usefull for you. Best regards mirouWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
