2005-03-31 7:44 PM
2005-03-23 11:41 PM
There is a Typo (type error) in the 71x_init.s file where the stack range are initialized. Instead of 265 (which can cause stack misalignement) it should be 256!
Could you confirm whether the problem is fixed on the latest lib version?2005-03-24 1:04 AM
Hi oli32,
Yes you are right it's a mistakes in the STR71x Library, it's already corrected in the lastest lib version which will be available in the web site soon. Thank you and best regards, Hich ;)2005-03-31 7:44 PM
Hi all,
The STR71x software library V2.0 is already published on the STMCU web site. Cheers, Hich :pWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
