2005-10-19 11:16 PM
2005-10-19 10:51 PM
Hello Forum,
Revision 6 of the STR71xF Datasheet specifies the ADC with a resolution of typ. 12 bits on page 43/49. Revision 6 of the STR71x Microcontroller Reference Manual says in a Note on page 331/345 ''Only the 11 most significant bits out of these 16 bits (of the ADC_DAT[n] registers) are guaranteed to be accurate according to the device specification, even if all the 16 bits can be read.'' I find this very confusing. Could you please clarify on the ADC resolution and errors ? Thank you very much. Regards Ralf2005-10-19 11:16 PM
Hi Vader,
The STR71x ADC have a 12 bit of resolution, this info will be corrected in Rev 7. Cheers, HichWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
